SOURCE: Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
SOURCE: My HP LaserJet 1020 don't print pdf
go in contact with HP help and customer support....or read ur instruction booklet under trouble.shooting aand help......
SOURCE: HP Laserjet 1200 prints pdf documents slow
pdf documents are historically slow, they usually depend on how they are created and how many attachments or upgrades have been added to the document. this accounts for some of the variations of speed the documents are printed.
SOURCE: my hp f 380 printer wont print pdf documents
in this case
open pdf
the click on print
now you need to look for the option that says print as image and this option has to be checked
you can get the option by clickon on advanced or prefrences
Thanks
