Question about GE Security DVMRe-16CT-600 16-CHANNEL Color Triplex Multiplexer-Recorder with 600-GB Hard Drive, Ethernet
Password I'm a tech working on the GE DVMReZ Triplex, but have no password to access the menu, Is there a standard password I could use to get in?
  • Onefootlarry Jan 09, 2008
    I have the exact same problem.
  • haddock03 May 21, 2008
    I change the default installer password. I dont remember the new password. How I will reset the installer password?
  • 3 Answers
Please find the following passwords.
Ten and Sixteen-Channel Units
Password Type Access Level Function Changeable by user?
Default Password Operator Operator Provides access to the Operator and SystemView menus. Press ‘ENTER’
4 Times
Installer Installer Provides access to all on-screen menus. Password 3 4 7 7
Factory Defaults Installer Resets the multiplexer to the factory defaults (except the time, date, email addresses, and email
IP address). Password 8 1 1 1
Language Installer Provides access to the On-screen
Language menu. Password 5 4 1 5
Ethernet Access Reset Installer Deactivates the ethernet
password, so that the unit may be accessed by any PC equipped with WaveReader. Password 1 1 1 1
Posted on Apr 22, 2008
6ya staff
SOURCE:
How can i rest a password on my truvision dvr30
The TVR 30 is shipped with one predefined user for the system administrator and
seven predefined standard users. The default system administrator logon uses admin
as the account name with a default password of 1234. You can modify the admin
password but not the admin user name. The seven predefined standard users are
labeled User1 to User7 with a default password of 4321 and level 4 access. The
administrator can customize the seven standard users and define their privileges.
Use the Users screen (shown in Figure 20 below) to manage users.
Note: When accessing the main menu for the first time, the system lets you pick
either an admin user or a regular user (User 4) by default. If you select User 4, enter
the initial default password of 4321.
Dec 28, 2014 | GE TRUVISION DVR 30 8CH 2TB
Default password
If memory serves me correct, most of the GE/Truvision etc. DVRs have to be sent back in for the password to be defaulted. I may be incorrect on this, will double check.
Jan 01, 2014 | GE Security DVMRe-16CT-600 16-CHANNEL...
Reset parental password GE 25GT240
The parental control password is entered during the setup procedure which you should be able to access using the remote. Once the setup menu is displayed on the screen, you should be able to guess your way through it to turn off the parental control
Jan 16, 2013 | GE 25GT240 25" TV
I have a 32 in Ge tv. Kids messed with menu settings. Turned brightness down, subsequently, Cant see menu to correct, need a navigator - walkthru
You have to contact the GE authorised service center to rectify this fault. TV deed to be opened. Seek tech support.
May 31, 2012 | GE Televison & Video
Installer code
Hit menu button, top right of jog, installer code is 3477, then use jog and dial to change settings. These must be done locally!
May 21, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Help me!
I have strongly recommended that change your power supply with the same specification voltage and amp. I have installed so many GE DVR's most of DVR's restart when the power supply is not working properly or HDD have bad sectors. I also recommend use the scan disk on you HDD for proper checking of your HDD.
FROM
AI
Jan 29, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Accessing the service menu
This is the right way, what is wrong with set?
Oct 06, 2007 | GE 31GT659 31" TV
GE Security DVMRe-16CT-600 16-CHANNEL Color Triplex Multiplexer-Recorder with 600-GB Hard Drive, Ethernet Logo
2,749 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
