Smeg FAB32 Bottom Freezer Refrigerator Logo
Gavin Dancy Posted on Jun 08, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Smeg Fab 32 door problem
I have a smeg FAB32 fridge freezer and have noticed that the fridge door is out of line and does not seal properly. The gap between the top of the door frame and fridge is 2.7cm at the top and 2.2cm at the bottom. Is it possible to adjust the hinges? I am fairly practical.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2788
Points
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
Anonymous
Level 2:
  • Expert 183 Answers
  • Posted on Aug 21, 2007
Anonymous
Expert
Level 2:
Answers
183
Questions
0
Helped
102360
Points
278
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
What s the switches inside fridge
prob green power yellow or orange fast freeze
SMEG fridge freezer, freezer door was left open and it defrosted. we have turned the applience on again freezer is contantly triping and it is not working. red light is on constantly. please help
the relay is timing out this was caused by over run try turning off for 1 hr to let it settle and decompress if it does the same fit a new relay and try if that does not work it meens the compressor has gone expensive repair
3helpful
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Widths
no
what part of the world do you live as there is other manufactures
Leaking Fridge
you may have a faulty defrost timer, best consult a local dom apps store.
2answers
Freezer problems
remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
Top Smeg Refrigerators Experts
Jay Finke
Jay Finke
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
