Trouble code flashes 8 times
Hi, if it using a Rhino controller 8 bleeps it means the following
The motor is not connected to the RHINO, or there is a short-circuit in the
motor connection. The scooter does not drive.
• The motor brushes may have lost connection. Turn the wheels of the
scooter to reconnect the motor brushes, and then turn the RHINO off
and on. If this happens often, the motors may be faulty.
• Check that the motor cables are not loose or damaged.
I suggest you check the cable from the controller to the motor , check the actual connector block a white colour connector, then check the brushes , do they move freely within the motor, stray some contact cleaner in the there plus on the connectors and refit cable onto the controller. please keep me updated. Regards GeWiz.
