Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tim Horton's home brewer Bunn coffee maker
I was given a used Tim Horton's home brewer, and older white model without instructions. How does it work???????
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11989
Points
10
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Anonymous
Level 2:
  • Expert 131 Answers
  • Posted on Feb 13, 2009
Anonymous
Expert
Level 2:
Answers
131
Questions
0
Helped
104053
Points
301
Before you plug in the brewer, pour water into the top of the brewer, put the pot back on the warmer, and close the lid. after the water finishes running down into the tank, repeat this step. after the second pot, water should start to come out of the sprayhead and into the pot. after water quits running, plug in the brewer. The brewer should heat up in about 15 minutes. Make sure that the switch on the side of the brewer is turned on. Once the brewer has finished heating, you are ready to make a pot of coffee. Put a filtewr in the basket - it pulls straight out the front of the brewer- put in your coffee, pour a pot of water in the top, put your pot back on the warmer, then close the lid. Within 3 minutes, you should have a hot pot of coffee. If you leave home for more than a day or two, you should turn off your brewer heater, so you don't lose water from condensation. this will cause damage to your brewer. Enjoy your new brewer!!
Anonymous
Level 1:
New Friend:
  • Posted on Aug 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11989
Points
6
My on/off switch is burnt out. Can I fix it myself? <!-- from fixya rte -->
Anonymous
Level 1:
New Friend:
  • Posted on May 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11989
Points
I clean my Tim hortons coffee maker almost every week otherwise it only drips in. Is this amount of cleaning normal? What else could be wrong? I just put descaler through and it worked fine for a day. Any other suggestions?
Anonymous
Level 1:
New Friend:
  • Posted on Sep 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11989
Points
Cleaning tim hortons coffee machine
1 Related Answer
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 20, 2011
SOURCE: just bought tim horton coffee brewer by Bunn model
I believe it is a good unit, only thing, is make sure you to the cleaning and descaling on at least a 3 month schedule, depending on average use.
Hello, My name is Mike I am a Espresso Expert. There is so many things these days that can cause your machine to have a problem. Companies are great at producing machines for consumers to purchase, but weak when it comes to helping a average person at home to trouble shoot the problem and only a few can fix it them self. So what I did is down load the complete manual for your machine as well, as it has schematics and trouble shooting guide along with how to fix it if you feel you can tackle that project. So, download the manual and you determine if you can fix the problem that you find on your machine via this manual. Please if you can, rate my free help and some kind words with comment would be appreciated too. Thanks Mike.
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Here is also my personal page of ads of my expertize (via fixya) where you can contact me , click on my ads, and read all my areas I am a expert on (appliance, automotive,electronics)
http://beta.fixya.com/users/mc1bean
2answers
My bunn nhb makes a continuous "boiling" sound even after coffee has brewed.
Check with Bunn and see if there has been a recall. I did in Canada and they sent me a new machine complete with some Tim Horton's coffee! http://www.bunn.com/
Good Luck!
How do you clean the Bunn 10 cup classic comercial coffee maker it is a BX-B model?
To clean your brewer, with the machine still turned on, pour in 1 qt of white vinegar and let it sit in your brewer for 2 hours. At the end of 2 hours, you will flush it out with 8-10 decanters of water.
1helpful
3answers
I don't have a manual, i have a tim horton bunn coffee maker, works great, but i'm worried about the resevoir, how do i fill it - how do i make sure it is always filled, andwon't dry out??
If you are using your machine everyday, it won't dry out. If you will call us at customer service at 800-352-2866 we can send you out a manual for your machine.
Bunn 10 cup home coffee maker
It sounds like a seal/gasket is defective causing it to leak. Please locate the model and date code on the bottom of the brewer and contact customer service for troubleshooting and replacement options.
5helpful
1helpful
I need a wiring diagram for a Bunn BX coffee maker
I do apologize but these diagrams are not available. What is the problem with the machine? If you will get the model and code date from the bottom of the brewer and contact customer service, we can help resolve your issue. The machine carries a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, then it will be replaced at a reduced price.
Bunn Coffee Filter Basket Tray Broken
If you will contact Customer Service at 800-263-2256 with the model and date code, they will be happy to help you. The tray assembling itself is not replaceable but the machine does carry a 3 year warranty.
I mislaid my instruction booklet, how do I clean my 10 cup home coffeemaker? Bunn coffeemaker purchased from Tim Horton's.
With your brewer still turned on and full of water, pour 1 quart of white vinegar into the top and place the decanter on the base and close the lid. Allow the vinegar to stay in there for 2 hours. Then you will need to flush out the machine with 8-10 decanters of water. There is a manual located on the website www.bunn.com. Select @ home then go to products. Select the model and then there is an option to download the manual. Or you can call customer service with the model and code date and a manual can be sent out to you.
4helpful
No instructions
There is a complete instruction manual available on the website. It is www.bunn.com Select @home and then products and select the brewer. Then there is a use and care manual that can be accessed on-line. You can also call customer service and a manual can be mailed out to you at no cost.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
