Question about Canon PIXMA MP280 Photo Inkjet All-in-One Printer, Copy/Print/Scan
How to make darker copies - Canon PIXMA MP280 Photo Inkjet All-in-One Printer, Copy/Print/Scan
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
1) HOW DO I GET A DARKER "COPY" FROM MY LEXMARK 2500 PRINTER? I HAVE TRIED EVERYTHING, AND I AM WASTING TONS OF PAGES AND INK TRYING TO GET A DARKER PRINTOUT. 2) I ALSO CONTACTED LEXMARK ABOUT...
To get a "darker copy", load your document on the printer > launch Lexmark Imaging Studio on your computer > click Copy > select Document or Photo > click Start > from the Quality drop-down list, select the best copy quality > click Copy Now.
For your other concern, please contact Lexmark technical support for additional assistance.
Jun 18, 2011 | Lexmark X2500 All-In-One Printer
Bottom of the copies are darker than the top I
There may be spilled toner inside the copier, Free the drum and paper way of toner an ensure the toner container is not over full. do proper cleaning and the copier will be okay.
Jun 10, 2010 | Kyocera Mita KM-2050 Printer
Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Feb 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
Instructions
for making darker copies it will always be on top where all the functions are.
all copiers are different will have different access.
Aug 19, 2008 | Office Equipment & Supplies
1/2 Page Darker
Did you put the old cartridge back in with the same out come? Also when the orginal is being scaned dose the scanning lamp turn off in the middle of a copy?
Mar 05, 2008 | Canon PC981 Copier
Modixerox 5510 functioning
Digital copiers will copy very light if the optics (mirrors, ccd lens) are dusty (opposite to the old analogue copiers which got darker) Clean whatever you can get at with a soft dry cloth.If it prints light from your computer then it won't be the optics, could be the ROS unit. If the ROS unit is dirty that's somewhat more complicated, the only bit you can get at is the ROS window, you'll have to pull the drum out and clean the glass window you can see from there
Jan 20, 2008 | Office Equipment & Supplies
Canon PIXMA MP280 Photo Inkjet All-in-One Printer, Copy/Print/Scan Logo
151 people viewed this question
Clive
Clive
old marine
old marine
Ekse
