Here's a diagram of the timing belt and serpentine belt.
SOURCE: serpentine belt replacement
The grand caravan should have a diagram showing the proper placement for the serpentine appropriate to your engine. There is usually a sticker showing the belt placement and travel direction on the front most engine cover (plastic splash shield over the radiator). You will likely require a special tool to loosen the tensioner so that you may easily replace the belt. Do not attempt to do this without the appropriate diagram and path.
If the belt is still making noise or slipping you can purchase an upgrade belt which has traction grooves on both sides, this is a commonly needed solution for the grand caravans.
SOURCE: I need a diagram for a 1994 dodge grand caravan se
Try this
Testimonial: "you did find the diagram that works, thanks."
SOURCE: need serpentine belt diagram for 1994 dodge grand caravan
if you buy your belt from Autozone the belt routing is on the box
SOURCE: Need serpentine belt routing diagram for 1994 Dodge grand caravan
3.3L?
Looking at the engine from front (right side of the Van): Stating at the Top, Going Left to Right and Clockwise:
Over the Alternator
To under the Idle Pulley,
To Over the AC Compressor.
To the Left Side of the Water Pump.
To the Right side and Under the Crankshaft Pulley
To the Right side and Over and Down the Tensioner
To Under the Power Steering Pump
And Back up-to the Left side of the Alternator.
Advise when puting it on:
Put the Belt around everything else accept for the Alternator. After it is around all the rest of the Pulleys - Pull the belt up - tight from the Power steering Pump and the Idle Pulley to form a loop, holding the Belt close to the Altenator Pulley.
Using the 15mm wrench or belt tensioner bar - rotate the Tensioner Pulley towards the front of the Van and then place the belt over the Alternator.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
SOURCE: need diagram for serpentine belt for dodge caravan 1991 free online
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
For the 1991 Dodge Grand Caravan:
http://www.2carpros.com/car_repair_information/year/1991/make/dodge/model/grand_caravan/1991_dodge_grand_caravan_drive_belt_routing_diagram.htm
Testimonial: "thanks for your help it was along time ago and forgot to let you know thank you so much "
