Won't retract
SOURCE: Olympus FE-210 lens does not come out
Hey memiche,
You could try resetting the camera to the default factory settings, and directions on how to do this are on page 20 of your camera manual. If this doesn't work then there is either something obstructing the movement of the lens (i.e. sand), or damage to the lens mechanism. If it is something obstructing the movement of the lens you could try blowing compressed air into the side of the lens to try and dislodge whatever is in there. If that doesn't fix the problem you could try putting the camera on a flat surface with the lens pointing up and holding in the shutter button, and while doing that turn the camera on. If none of this works I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/FE-210%20Advanced%20Manual.pdf
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: the lens won't retract
If the lens is stuck out extended you may want to call Olympus Customer Service to discuss repair process and pricing. If the battery is fully charged and the lens still stays extended then this is a clear repair issue as something in the lens assembly has failed. Their telephone number is 800-622-6372 option 2 and then option 3
SOURCE: I dropped my olympus 540 zoom camera and lens cover is jammed
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: The lens won't come out
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
1. Sand or foreign object in the lens cover.2. bad motor or gears.
Try cleaning with canned air while powering the camera up/down...
