I filled up an SD card with pictures and uploaded them to my computer. When I tried to format the card with my camera through the set up menu like I always do, everything seemed fine. Wrong. Now my camera still shows "memory full", no matter which SD card I try to use. Even the internal memory shows up full even if there are no pictures left anywhere. I tried resetting the camera, draining the batteries, putting new ones in. Nothing works. My camera won't let me take any pictures and insists that the memory is full. Please help.
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
SOURCE: My screen's camera says, "Card is Full."
in camera memory is alredy full but u say only memory card formaat pls look the camera memory and no answer that the card is full
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
SOURCE: My FUJI A850 says the memory is full even when the
camera is not able to read the memory car ot may be there is some virus in your camera try to scan it on comp thru some anti virus...remove battery and leave it for 30 mins then try...
Thanks, but no. I checked that too. And I tried with two other SD cards that aren't full and are unlocked.
Apparently, taking out the batteries and letting the camera sit for a few days made the problem sort itself out. When it was powered back on, the message still showed, but swapping SD cards again, it disapeared and everything seems back to normal. Hoping this never happens again!
