Start by plugging in the green audio jack into an mp3 player or even smartphone and test the speakers. If they still crackle then I would say replace the speakers. If they don't crackle then try going to Dell's website, search your model and update your audio driver.
That because maybe due to your itunes player which the installation got error..please try another player other than Itune or play it in windows media player or some other player which you think good player.
Or try reinstall your player or update it.
if this not resolve the issue, then verify the connection of your sound card maybe got grounded to other components making the sound crackle..Or you may try attached a grounding wire from your stuff directed to the ground or attached in any metal that is connected to the ground to eliminate noise.
please tell me what ever result for further analysis
A quick way to check your speakers is to put the contacts from a 9 volt battery to the positive and negative speaker wires (briefly). You should hear a crackle of some sort if the speakers are functioning. If there is no crackle, speakers are bad / if there is a crackle, your head unit must have a problem.
This could be caused by one of your speaher wires being shorted out to ground, OR one of the speaker terminals in the doors or rear coming into contact with metal. If you remove the unit and test it with the speakers hooked directly to the back of the unit and they do not crackle, then the unit is fine. If they still crackle - then you either have two diferent sets of bad speakers, Or more than likely the outputs of the kenwood have been damaged by an improper installation in the past.
Let me know what the Type Numeric Number and Model Number on the bottom of the laptop is. I can look on IBM website and see where the hard drive is in located to the speaker. It has happen on some HP and Toshiba I know from experience where the hard drive causes the speakers to crackle. Not sure why, maybe not enough shielding. The type has 4 Numeric Characters and the Model has 3 Alpha/Numeric Characters.
