My phone is not charging very well i'm not sure if the battery is dying or if the charger lead is not working is it possible to replace either of them
Quick Charge 2.0 2port QC2.0+4port USB Charger 5V 9V 12V 60W USB Fast Charger for Mobile Phone Chornic Quick Charge 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Please try it My Dear Brother:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: battery charging
Sony ericsson phones have a weird way of diconnecting the charger from the phone, u have to pull up at a 45-50 degree angle to release the cable, perhaps you have accidentally twisted the pins inside the actual phone, or the may be dust obstructing the pins in the phones socket
SOURCE: Sony walkman phone faulty charger connection so can't charge
you need to take the phone to a mobile service center and have them service the charger port
