Check the power supply: Ensure that the food processor is properly plugged into a functioning power outlet. Sometimes, a loose connection or a tripped circuit breaker can cause power issues.
Safety interlock system: The Kenwood Multipro 910 food processor usually has a safety interlock system that ensures all parts are properly assembled before it can start. Check if all the components, such as the bowl, lid, and blade, are correctly locked into place. If any of the parts are not properly assembled, the food processor may not work.
Motor overload protection: If you have been using the food processor for an extended period or with heavy ingredients, the motor may have overheated and triggered the overload protection mechanism. In this case, you will need to allow the motor to cool down for some time before it can restart.
Fuse or circuit breaker: Some food processors have a built-in fuse or circuit breaker that protects the motor from electrical surges. Check if your food processor has a fuse and ensure that it is intact. If it has a circuit breaker, reset it if necessary.
Mechanical issues: If none of the above steps resolve the problem, there might be a mechanical issue with the food processor. It could be a faulty motor, broken wiring, or a malfunctioning switch. In such cases, it is advisable to contact the Kenwood customer support or take the appliance to an authorized service center for repair.
Parts Townhttps://www.partstown.com > HOB-A200_spm
PDF
A200 Mixer 115/60/1 Technical ManualPage 2 of 43 ... Manual Bowl Lift ... If service is needed on this equipment, contact your local Hobart Service Office.
43 pages
I am sorry to hear you are having trouble with your appliance. I have added a link below for our help video on setting the correct speed on your mixer.
Hi Debbie. Your speed control either needs adjustment or repair. You can download for free, a Kitchenaid Service manual from www.mendingshed.com This will help you or a tech to do the necessary work.
If this solution has assisted you, please rate it. Good luck! ricardok45
On page 11 of the manual, note there is a screw that enables changing depths of mixer attachments thus preventing scrapes on bowl. These adjustments must be done rather slightly. Do not over-adjust. Click a degree or so at a time. Trust this resolves and happy cooking (or baking) as the case may be.
