We unplugged the unit and now it will not power on. We tried to remove the front (removed the 2 screws first) and cannot get it off. WE are looking for the reset button as maybe that is the problem. All the standard troubleshooting has been done. How do we get the cover off and where is the reset button? model number is ALX08F2BCOM
Sounds like a blown fuse.
Look for a red reset button on the plug.
Take the buttons off of your unit and remove the board cover by taking out the 2 screws on each side holding it in. You will See on the right hand side of the board 4 post specifically , 2 for your indoor thermistor and 2 for your outdoor. unplug your inddor from the board ( make sure power is off) and there should be a plate you can remove on the front of the unit on the right hand side of your evaporator coil , remove this and disconnect your thermistor from the coil (should snap right off ) pick up a new thermistor and just slide it right back in.
