Yes I have a 10.1 irulu tablet it has a 3g network i doi use my 3g network instead of my wifi its already built into it i dont know what do i need to do to set up the 3g network
SOURCE: Samsung tablet isn't connecting to
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
Hello friend
(("You must remove the
battery, then insert a SIM card into the 3G SIM slot toward the right
of the battery compartment"))
Definitely it will work
Hope this info is help ful for you....
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12
mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to
gather around on the sofa at home or slip into a carry case for when on
the go".
Archos Arnova 10 G2
