Euro-Pro Shark GI490 Iron Logo
Posted on Jan 12, 2009
Shark G1490 doesn't light up or heat up when I plug it in.
I've tried several outlets but the iron lights don't come on, and it won't heat.
  • rhoney636 Feb 14, 2009
    I am having the same problem. had my iron for a year. Was just ironing and all the lights went out on it. I switched outlets and it wasnt that.
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Aug 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
10216
Points
26
Circuit board has shorted out that control iron functions or power wire lead has broke off inside of iron
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
2answers
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
G1490 just stopped working. Second identical iron that just stopped working. Can manufacturer replace the iron free of charge?
Most have an 800 number and are willing to make replacements directly to the consumer...call them and find out...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Iron will not turn on
heatman101
Shark model G1490 won't heat. Can heating element be bad?
if lights are coming on its either the wire that send power to the heating element or the element itself
I have a brand new Shark G1490. When I plug it the light turns on, but it does not get hot and besides this brown water comes out. what should I do? please help me.
push button down on top of iron to turn on iron and adjust settings and do a self clean to remove debris and scale build up from iron
Without function no power
heatman101
My G1490 Shark Iron will not heat up.
your heating coil probally went bad its alot cheaper tp just buy a new iron
Iron won't heat
send me manual on iron g1490
john reilly, 5640 hwy 14 w janesville wi 53548
asap
thank you
5helpful
3answers
Shark Euro-Pro G1490
Our G1490 quit after one year. Just won't come on. Period. I can't get it to open after removing the back screws either.
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
