The light turned off while in use. Mop seems to be working but the light won't turn on again
SOURCE: Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
SOURCE: shark steam mop has water, but there is no steam....
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may
not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
SOURCE: shark steam mop does not create steam. 7 mos old
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
a
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
SOURCE: Shark Steam Mop - Gray/ Purple Vacuum: shark steam mop has water, but there is no steam....
I tried running vinegar through as you would a coffee pot to get rid of hard water scales. This did not work. Then I noticed that the light behind the shark decal on the front of the machine was going off and on. And sure enough as I moved the cord around the light would come off and on. Looking closer I could see the the heat had melted thru some of the cord.I bought mine at Target before xmas last year, throwing away the sales slip after several months so I guess there is nothing I can do about it.
