Fridge not Getting Cold, Freezing Part on Back.
Que debo hacer
para repararlo
Replace the fridge compressor with another one, try a Google search and maybe you'll find result's for your specific fridge. If all else fails, then ring up your fridge manufacturer and talk to them about your fridge, and if you still have warranty and you complain hard enough, they might just send in a new compressor.
SOURCE: Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from
Haier places, but I just took the motor out and took it to an appliance
repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
SOURCE: After my mini fridge was left open over night, it doesnt get cold anymore....
Being left open can let lots of moisture in that can freeze up the air circulation paths. First thing is to leave it off and unplugged for a couple days to melt any hidden ice build up from being open all night. Then start it up like normal and see if it works properly. If not then repost and we'll go from there.
SOURCE: fridge won't quit running and get cold
2 common problems that unit has. 1 is the cold controls go bad and will cause the unit to either run or not run. 2 the freezer drain gets blocked up very easy and when the freezer defrost the water has noplace to go but the freezer bottom and could block the air passages so the cold air will not satisfy the control. so check the freezer bottom by removing the plastic peice on the bottom there are 3 plastic plugs in the front that secure it and some phillips screw in the middle. you can just lift it to check for ice. if there is none replace the cold control. good luck
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement. Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect. If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply. Thank you.
SOURCE: Fridge will not get cold
Was your fridge transported upright at all times? There are warnings on most brands not to lay them down due to potential damage. If that was not the case, those small units are often easy to repair.
[Note to garing: The person said there was no ice anywhere but on the back. Dorm sized refridgerators are rarely frost free, so your answer was pointless.]
