Question about GE WSXH208A Front Load Washer
How do you clean pump on front loader washer? red light said to clean
  • 113 Answers
Theres a tutorial www.shop.washermd.com to clean a pump. Dave
Posted on Jan 14, 2009
6ya staff
SOURCE:
Philip
  • 949 Answers
SOURCE: Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Posted on Apr 21, 2010
Anonymous
  • 1028 Answers
SOURCE: washing machine
bottom right corner behind the little door
Posted on Sep 27, 2008
Anonymous
  • 91 Answers
SOURCE: Red light on - clean pump
remove bottom panel 3 screws7mm once removed access to pump im front clean and reinstall thats it
Posted on Jan 03, 2009
tbirdfan1
Michael Thomas
  • 3051 Answers
SOURCE: hi have a front loader
hello there again please dont forget to give the chat session a rating for me ok
Best regards Michael
Posted on Dec 05, 2009
Testimonial: "thanks it was helpful but i cant seem to detach the pump!"
MS_WI_3013
  • 119 Answers
SOURCE: How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Posted on Apr 26, 2010
My Maytag Front Loader Washer was reading sud on the digital screen and also reading F02. After a few days past by, it stopped reading that because i looked online and thought i solved the problem. Just...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Maytag EPIC MFW9700S Front Load Washer
Red light is on .Says clean pump i have cleaned out filter . Where is the pump?
Often, certainly on front loaders in my experience, the pump is visible after the filter has been removed. It should be possible to check that it is free to turn by hand/finger BUT REMOVE POWER FIRST!
It is possible to visually check whether the pump is working, with power on of course and the filter still removed, by selecting a spin cycle at which point the drain motor pump should start to operate.
Good luck,
John C
retired Englishman in SW France, 12:31 Friday afternoon- whoops, time for my lunch!
Feb 11, 2011 | Whirlpool GHW9400SU Front Load Stacked...
Washer won't drain. Pretty sure it's clogged but not sure how to check for this.
Hi, You don't mention whether this is a top loader or front loader. On the top loader you need to get to the drain pump. Front of washer may come off or the lid comes off and then the front. Some of them had clips under the console. Once you are at the pump, take a shop vac and empty the water. Both hoses inlet and outlet will have to be removed and cleaned. BEFORE YOU DO ANYTHING ON THIS, UNPLUG THE MACHINE!!! If its a front loader the kickplate has to come off or the whole front, and same procedure as above. Hope this helps.
Jan 18, 2011 | Washing Machines
My Whirlpool front loader washer has "clean pump" light displayed. How do i clean the pump.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Whirlpool AWOE8748 Front Load Washer
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jan 03, 2009 | Washing Machines
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore front loader
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
GE WSXH208A Front Load Washer Logo
76 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
