Panasonic DMR-EZ47V DVD Recorder/VCR Logo
gavin reid Posted on Apr 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic dmr-ez49veb wont play dvd-r discs
I have just bought a Pan dmr-ez49veb after my diahatsu combi finally conked out & is now apparently obsolete.I have lots of taped off TV stuff on both dvd+ & dvd- not really knowing the difference & as both worked on the dia,not really bothered.I find though this Pan only plays the Dvd+ discs & says the Dvd- ones are IncompatiblE even though the instructions hint this disc ShoulD be More compatible. I,m not technically minded so finalising,burning & downloading go over my head & the thought of taping of those progs again turns my stomach,Help?
Dennis White
Level 2:
Habit-Forming:
Scholar:
  • Expert 36 Answers
  • Posted on Apr 25, 2017
Dennis White
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
36
Questions
10
Helped
13396
Points
109
I would suggest contacting Panasonic support. You can search for their website/home page for their contact numbers. Typically, manufacturers maintain help, support, upgrade, forums and FAQs/knowkedge bases to help customers troubleshoot their appliances/equipment. I have used similar methods, previously, to update/upgrade the firmware on an "obsolete" DVR and it has lasted 4 more years (still working).
5 Related Answers
A
Anonymous
  • Posted on Oct 31, 2007
SOURCE: Panasonic DMR-ES30V
I have three Panasonic DVD recorder/Vhs combos and I get the same problem from time to time...it may be the disks you are using.  Mine absolutely hate Sony disks.  I have the best luck with TDK or Maxell.  You also must clean your unit frequently, if you do alot of recording.  I use my units daily.
Hope this helps
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on May 28, 2008
SOURCE: I have a panasonic dvd
ok this is easy you bought new disc's
new disc's these days are running new cd dvd format which is makeing old players useless i guess there weeding out piracy i guess but with this being the way it is i would upgrade player writer
Anonymous
  • 70 Answers
  • Posted on Oct 05, 2008
SOURCE: PANASONIC DVD-REC/VCR COMBO with Integrated Digital Tuner & HDMI-DMR-EZ47V playback
When you say downloaded movies are they avi's, vob's mpegs, mov's or windows media files? Which files are you using on the cds? what software are you using to burn the discs? When you burn onto cds are you creating VCD's or just data discs. When you burn onto a RW disc it cannot be finalised. I think you are possibly either not using mpegs or vobs or you discs are not being finalised. (When i say vobs i mean dvd compiled and compatible discs)
Anonymous
  • 39 Answers
  • Posted on Mar 09, 2009
SOURCE: Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Anonymous
  • 93 Answers
  • Posted on Sep 14, 2009
SOURCE: DMR-EZ48V- DVD drive not working
Check Panasonic.com for Firmware updates. If it has a reset button reset it. Take off the cover remove dust and lint, also clean laser eye with rubbing alcohol. DO NOT LOOK DIRECTLY AT THE LASER LENS IF YOU PLUG IT IN, DURING THE OPERATION.
2helpful
Brand new dmr-ez49veb,has worked ok on setting it up.it is now stuck in vhs mode and will not respond using remote to select tv mode.I have scart and hdmi connections to tv and have tv input selected to...
i have a panasonic dvd rcorder / video combi model DMR-EZ49VEB. I have recorded something on DVD, which is 4 hours in duration, and I want to edit the recording and split it into parts. I follow the manual, but when I press EDIT the option to split isnt even there? I am confused, it is SUCH a difficult manual to deciphre, but the only 2 options there are "Edit title name" and "Change Thumbnail". The others are not listed. the disc is not copy protected or locked and is of sufficient duration to split the contents. HELP PLEASE :(
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
2answers
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Panasonic DMR ES40v
We need to narrow down where the problem lies. Even without finalizing the disc, you should be able to play back the recording. Can you do this? If you can play back the recording, the problem exists in the finalization stage and we'll need to concentrate there. Please update this and we'll proceed to the next step.
Thanks,
Viper
1helpful
Panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
4helpful
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
Panasonic DMR ES30V DVD and Video Player Combi: SLF Error
try washing the disc in a mild solution of laundry soap and bleach. i don't know why it works but it does. wash it, dry it and put it back in the machine and go to finalize the disc. finalize it and it is as good as new david
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
