SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
SOURCE: AT&T uverse remote code for Sony KDL-46V3000
hi! i have here a couple of codes for your SONY tv, just try them 1037, 1128, 1137, 1178, 1215, 1216, 1218, 1219, 1220, 1221, 1250, 1251, 1316, 1318, 1330, 1347, 1413, hope this helps!!!! goodluck!!!
SOURCE: I need a table top stand for Sony Bravia KDL 32 BX
We just discussed and discovered how to solve this problem in chat session, hope this will help.
Thanks.
SOURCE: need a remote contol code
Hello 038 533 679 505 533 038 039 064 102 130 505
Remote codes for Sony TV with Sky Plus remote are:
Ok.
SOURCE: sony bravia 32 inch lcd turn off after 20 minitus bx series
try to check the settings first may be it set to auto shut off every 20 minutes then disable auto shut off.
038
533
679
505
Ok.
