Top loading calypso a large nylon duffle bag slipped under the washtub a piece of it is sticking out but it will not allow me to work it out.I do not have an owners manuel so I can't find out how to get under the tub.
It's quite a long process to remove the wash tub! Read all of this before starting - including the part about new parts #1-unplug the machine \ turn off water! #2-the top of the cabinet must be lifted from the front (slip a putty knife into the front groove to release the right & left clips - about 6" from corners) #3-carefully lift top up from front until it is vertical (support it so it won't fall) #4-undo clips and hoses that hold tub top ring in place and carefully remove it #5-plastic top (cap) of agitator in bottom center of tub must be removed (short screw driver should unclip it at four small holes) #6-remove 6 bolts from around inside of area that was under cap and remove plastic washtub bottom as well as center plastic dome #7-now center keeper nut must be removed from universal joint for agitator - now the whole steel tub should be able to be lifted off of the splines (pay attention to the relationship of the splines so you can put it back just as it was!! Now you should be able to clear everything from the area that was below the tub! Also check the outlet for any other clothing items!! when this all goes back together, its recommended that all new rubber washers and seals be used to make sure that the universal joint assembly stays dry!! GOOD LUCK
