The pump was pluged up and would not drain. I took the drain hoses off and cleared them and the pump. When I tried to start the machine the error code appeared on the screen and the machine would not run
I would make sure that your using HE detergent. The FO2 error code can occur from a suds lock caused to too much detergent or not using high efficiency soap. If you are using HE soap then the problem is going to be in your drain pump. Its fairly easy to clean just google a how to on clearing the pump. Theres also some how's in the "tips" section on this webside. Hope this helps _MJ_
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
This is most likely an "FO2" Code.(Long drain). Any time the experiences a draining issue, this code will show. Check the following to address this issue.
If the drain time exceeds 8 minutes, the water valves are turned off and
F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4
minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is
running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Sorry the error code was Err Loc.
