Samsung Digimax A7 Digital Camera Logo
Janice Obergefell Posted on Jun 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung Digimax A7 digital camera
I have recharged the batteries, tried new alkaline batteries,and the camera shuts itself off within 2 seconds of turning on. The shutter is almost closed, but will not open when the camera is turned on.
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jun 12, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1028191
Points
5636
Contact the Samsung Technical support for a repair opinion Then look up your local Internet for a repair firm Bear in mind the likely cost will be heavy. It may be a case of you paying a lot of money for shipping/insurance/Inspection/only to find it cannot be repaired because of lack of parts.
I turn on the camera and as soon as it comes on it shuts itself of
This is a symtom of weak batteries.
Please remember that the alkaline type of batteries will not last. The lithium type while more expensive, dollar for dollar, will outlast them.
A cheaper alternative is to get a charger and Li-Ion rechargeables.
1helpful
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Digimax 401 keeps saying batteries low
the camera tends to take up a lot of battery so what the best solution is to buy some rechargeable batteries those work great. i have some of those. and they tend to last a very long time!
Samsung Digimax D53 Digital Camera
refer to my answer I gave to:
bsnydto
why does my camera say low battery...
seems to be the same problem
Camera Won't Turn On
if your having battery problems then i suggest recharables...i got energizer AA rechargeable set and it works perfectly for me...hope this helps :D
Digimax A7: When I turn it on it turns off.
It seems i have the same problem...although my batteries do charge, and i can take pictures. But when I play them back It does this beep beep beep and shuts off and the lens doesnt always close. It's really pissing me off
1helpful
4answers
Displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
Won't take a picture
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2 (icon looks like a wrench with number 2 on it)
- Scroll down to Battery Type
Under Battery Type, there are two options:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
2answers
HELP!
Use lithium batteries. I had a problem when our camera would turn on for a few seconds, beep 3 times, and then shut off. The best batteries, which are actually recomended for this camera is the lithium batteries. I strongly suggest them.
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
