The larder is too cold even on the lowest settings the salad box goods freeze the freezer seems to be ok have checked for ice inside the unit but there does not seem to be any wondering if the thermostat is broken landlord has just installed new central heating system looked at the tube and evaporator dish there is a tube running into the dish which seems to have a flap at the bottom cant find an engineer to do the job not sure how to progress fridge is just over 2 years and out of warrenty
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
SOURCE: frigidaire PLHS267ZDB2--Not cold enough
Replaced the fan and the damn thing works like a charm....Thanks alot for all your suggestions.This is a cool site and you guys are doing a great great job! Keep up the good work!
SOURCE: Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
