Question about Directed Dei Valet 561r Remote Start/Keyless Entry
Replace battery in a valet remote start
I need to know how to replace a battery in a valet remote start i own a 2005 ford explorer sporttrac
  • 46 Answers
Have to do it within 2 mins....use a knife and split the case open the rest will be simple aftre that
Posted on Jan 14, 2009
6ya staff
SOURCE:
Reprogram remote 2005 Ford Explorer
You need a dealer to do this.
Aug 22, 2017 | Cars & Trucks
Battery went dead so replaced the battery but now alarm system doesn't work. Keyless entery remote works to open and lock doors but no alarm. How do I reset the alarm on Ford explorer 1999?
It sounds like the system is in valet mode. Depending on the brand and model that is installed, the procedure to turn off valet mode can vary. The most typical way is to turn on the ignition key and press and release the valet button, or if it is a switch, to flip the switch
Jan 25, 2011 | Ford Vehicle Parts & Accessories
96 SportTrac, started fine drove it and when I stepped on the brake the battery light came on and the truck died, tried starting the explorer it will try to turn over but will not start any ideas
Sounds like the immediate problem is getting the battery up to full charge and/or having it's condition checked, it may need to be replaced. It may be worn out and unable to hold a charge. Then a check of the charging system to verify the alternator is charging the battery. If the charging system isn't working properly it will just drain the battery again. Also take a look at the belt turning the alternator and connections. Ans as always use proper safety precautions when working with the battery. Do you know how old the battery is?
Jan 20, 2010 | 1996 Ford Explorer
Viper works but remote start and keyless entry does not
On the remote start part, it might be as simple as relearning the tach. To do this, crank the car with the key, press and hold the valet switch until the led lights and stays solid now release.Try the remote start. Need to know what kind of car to comment on doorlocks.
Jun 14, 2009 | Viper Security and Remote Start System...
Installation of a Viper 5901 remote start into a 2001 Ford Explorer Sport
viper 5901 remote start alam installing it on a 1997 ford explore i need a detail wiring diagram
Mar 04, 2009 | XX-67A II LED/Valet Switch Pod
2005escalade remote starter
did you install a "gm remote start bypass", like DEI model 556L?
if not it is the passlock that is not allowing the car to start.
Dec 19, 2008 | Directed Dei Valet 561r Remote...
My cig lighters dont work on my ford sporttrac
FROM THE OWNERS MANUAL:
FUSE #17 20A (FUSE COLOR YELLOW) Cigar Lighter, Data Link Connector
PLEASE RATE THIS SOLUTION,THANKS!
Dec 04, 2008 | 2001 Ford Explorer Sport Trac
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
1,989 people viewed this question
Top Directed Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ric Weide
Ric Weide
Level 1 Expert
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
