Tablets & eReaders Logo
A
Anonymous Posted on Dec 13, 2012
I cannot turn the sound on my disgo tablet 9000 it says its on mute and i do not know how to turn it on
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
86
Points
0
If it doesn't work after being reset or turned off and on, I think it's time to go to curry & pc world to get it fixed, I did that with my Disgo 9000 and they said they had many problems with them in the past and that they don't sell them anymore, the man then said that we can go and find a different tablet for the same price and they will switch everything over, no money needed, especially if you got the norton on the tablet they give you it free of charge, I now have a Lenovo 9" tablet.
1 Related Answer
Anonymous
  • Posted on Jul 29, 2013
SOURCE: just bought a disgo 8000 android tablet but it freezes every time I try to use the gallery
i have a disgo tablet 8000 but freezes when it gets to the disgo sighn what do i do?
1helpful
My disgo 8000 tablet has lost its recovery image and it says try to boot from sd,but i don't know how to do this. need lots of help please otherwise i just have an expensive brick.
Stop stop stop and stop using the device immediately! Once you use it again, it may cause the file overwritten situation which means your original files may be overwritten by the new files. To get back the recovery image, you can boot your disgo 8000 first. Then use this software to get the files back, here is the website: http://www.uflysoft.com
1helpful
Disgo is frozen on home screen and home icon keep flashing i cant do anything
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that.
It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press.
I hope this will help you and that your tablet will work fine for you.
Let me know if you had any success.
1helpful
3answers
Just bought a disgo 8000 android tablet but it freezes every time I try to use the gallery
We are sorry to hear that the device is freezing and not working as expected.
Please try the following which may help to resolve the issue.
1) Ensure that the Video/Image files you are trying to view are compatible with the tablet. Compatible files are located on the packaging and in the User Manual. You can also locate this information on the website, mydisgo.com
2) If you have not already done so, we would advise that you update the device to version 2.3. The update procedure can be found at the following page; tinyurl.com/8000update
3) If the Gallery app only freezes when accessing files on the SD card (and not internal memory), please try using the alternative memory card slot or test using a different memory card.
I do hope this helps to resolve the issue.
If you require any further assistance, please do not hesitate to contact us at mydisgo.com/support
Thanks, mydisgo.com
2answers
Disgo 7000
Try ebay at:
http://www.ebay.com
2helpful
How to do a full reset on disgo 6000
Try to restart your tablet and do it again.If not, contact Disgo for tech help.
Android 4.0 Tablet PC
2helpful
Digo freezes
It may hardware problem. It's better to contact Disgo for tech help. Or change it for a new one if it's possible.
1helpful
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
