Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS.. How To fix any Android Phone Tablet that won turn on
RedditApr 21, 2015 - The community doesn't take too kindly to it either. ... charged battery, or on just the power cord, but it will not go past the "Coolpad Arise" logo.
www.askmefast.com > Computers & Internet > Security > Screen
Coolpad 3300a wont go past the start screen where it says coolpad? ... Coolpad won t go past start up screen ... Software for avail coolpad 3300a phone ..... Can i get a new 4g coolpad for mertopcs if part of the screen doesn`t really ... coolpad phone model 3300a always freezing at the coolpad logo and how to unfreeze it?
Your question is incomplete. Your imac froze and wont reboot. What you see on screen when you start it? Do you see a spining wheel or a folder sign with a question mark or a blue screen? If yes then it's either corrupt/damaged osx or bad hard drive.
Good luck.
Tech from http://www.computerstar.ca/Macbook_repair_toronto.html
The below steps will resolve many small issues.1.Power off the phone. 2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode. 3.Use "Vol+" and "Vol-" to move the cursor up and down. 4.Move cursor to "wipe data/factory reset", press "Back" key to select it. 5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it. 6.The data will be erased. 7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally. WARNING: All user data will be completely cleared; the phone will be in a factory reset status.So before you reset backup data first!! gud luck!!
defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
sounds like you need a new phone but id take it to a where ya bought it and see if a different battery fix's problem. ive had a battery that would discharge all its juice at random and had that burn up a motorola. hope this helps
Assuming you've tried pulling the battery and booting it again, you could try doing a hard reset on the phone (this would erase all data on the phone), by starting up the phone while holding down the volume up button while turning the phone on, waiting until you get a white screen with 3 skateboarding androids on it, and select clear storage (use the up/down volume buttons to move the cursor, power button to select), then volume up to confirm. If the phone still won't boot up after doing that, you're going to have to take it to a store, as that boot menu is the only thing that you can get to come up if it won't boot all the way up.
