I tried to add a note in the create memo but it pin locked it self & i dont know the pin code
Say what I am a kid not a grownup
This worked for my galaxy sII - connect your phone via the usb cable to your computer, now open samsung kies on your desktop, select the backup/restore tab, select data back up, scroll to memo and select it, click backup button in top right hand corner, now go to restore data tab, select memo and click restore. select "add as new memo" and "apply to all" in the pop up window, your memos are now all unlocked with duplicate files, you wont be able to delete the original locked files but you can at least access your "new" memos now.
SOURCE: i dont know the phone lock code on my phone.
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
SOURCE: sph - A920 locked out by security code
Put the last 4 digits of ur phone number.If it not works it means that anyone change u r phones security settings.
SOURCE: my samsung galaxy ace is
More than likely, you will need to reset your password for your GMail to get back into your phone. Go to Google.com to reset your information.
If you are unable to do this, you will need to do a Factory Restore to your phone. WARNING: Factory Restore will erase all phone data. It will restore the phone back to the stage when you first purchased it.
To restore your phone back to factory settings do the following:
1. Power down the phone.
2. Hold the Volume Down button and press the power button.
3. A menu pops up, release the Volume Down button.
4. Press and release the volume down button to select "Clear Storage"
5. Next, Press and release the power button
6. To confirm, press the Volume Up button
The phone will run some tasks and then reboot. You may then signin with a new Gmail account. I suggest recording your new account information in a safe location for future reference.
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
