Sewing Machines Logo
Maha Posted on Dec 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sewing machine problem (Brother CE 8080 prod. code 885-V61) is tangled thread on wrong side of fabric, I followed the troubleshooting remedy but it still exist
Tangled thread on wrong side of fabric, I followed the troubleshooting remedy but it still exist,
sylviaivie
Level 3:
  • Sewing Machines Master 1,564 Answers
  • Posted on Dec 15, 2012
sylviaivie
Level 3:
Answers
1564
Questions
Helped
426418
Points
3583
Your top tension is too loose.
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Feb 23, 2008
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Anonymous
  • Posted on Jan 25, 2010
SOURCE: thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Anonymous
  • 6 Answers
  • Posted on Dec 21, 2010
SOURCE: I place the fabric on
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Sep 21, 2011
SOURCE: My Brother CE55000 sewing machine
Does it sew okay on a single or double layer as this sounds like the threading up is not correct to me. The grinding may be that the bobbin case isn't in correctly.
However, best way to diagnose is to start fresh, take off the thread, remove the bobbin case, clean out the rotary hook (under the needle plate) clean the feed dogs and remove the needle. Clean the tension discs too (turn to zero and floss between the metal discs with selvage edge of a clean piece of cotton scrap fabric, until its clean, no gunk coming out). Turn tension dial back to 4 or 5, your normal setting.
Now wind a fresh bobbin making sure it winds nice and smoothly, keep tension onto the thread spool to achieve this and watch as the thread goes onto the bobbin, give it a nudge so it fills the bobbin smoothly across the whole core, top, middle and bottom.
Now put bobbin into bobbin case and ensure it goes into the tension spring correctly. I can't see an image of your machine to know if it is top loading or front loading bobbin, sorry. But refer to your manual to ensure you get the thread fully into the tension device. With a front loading bobbin, there is a removable bobbin case. Ensure that this is holding the thread with enough tension, if you suspend the bobbin and bobbin case and just hold the thread tail there should be enough tension on the thread that the case just hangs, but if you give it a litle jolt, it should release some thread. Adjust the tension spring with a little screw on it in 1/4 turn increments until you get it to this point.
Try this link for some images and trouble shooting help on bobbin case. http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If you can't get the tension right on the bobbin case at all, then take it to the Brother shop and buy a replacment one, sometimes the springs do fail on them.
Now put in a new needle and make sure you have used the right size needle for your fabric, ie medium weight woven you need a size 80 universal, but if it is a knit fabric like jersey you need a ballpoint 70 or "stretch 70" if its got a lot of lycra in it.
Now thread up the top thread and pay careful attention to getting the thread into all the thread eyes, particularly the take up lever and make sure it goes into the top tension discs fully (always thread with the pressure foot raised so the tension device is open). Lower the pressure foot and pull the thread just before the needle, it should feel very firm if the top tension is working right. If there is no resistance there, you've got a dodgy tension dial, take it for service/replacment.
Continue threading to the needle, bring bottom thread up to the top by turning the flywheel through one cycle towards you. Now hold both threads together at the back and test stitch a seam.
If you are still getting the noise from it and thread jamming up underside then the fault may be more timing related in which case you'll need to take it to a sewing machine technician too.
Anonymous
  • Posted on Jun 18, 2012
SOURCE: Threads tangled in the wrong side of fabric when sewing?
This means your tension is incorrect. That circle with numbers about the needle is typically set at three. If not, start there and experiment number by number until your threads are equally taut on both sides.
2answers
Why does bobbin make thread bunch up
needle thread tension not tight enough to pull bobbin thread up into the material
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
1helpful
2answers
Tangled thread on wrong side of fabric, I did the remedy as per manual but problem still exist
Unthread the machine fully. Remove the bobbin. Is the bobbin thread the same as the top thread? Is it a Quality thread (yes, cheapie thread can give big issues!!) Do you have several different threads wound onto the bobbin?? Is the bobbin thread wound on quite tight? If you push your finger nail into the thread wound onto the bobbin, it must not feel soft or spongy. Check if there is any roughness / burr on the any part of the shuttle hook. If so, remove it with 800 grade wet and dry abrasive or similar. Put in a NEW needle as per user manual specs (not a 'new' one you used before 'just for a little bit'.!) REPEAT - put in a NEW needle - amuse me!!. Place the bobbin into the bobbin holder (the CORRECT direction - yes there is a Right and a Wrong direction!), thread it ready to put back into the machine. BEFORE you do, hold onto the thread tail and let the bobbin and bobbin case dangle. Thread should slip thru when you give a gentle pull upwards. If no slip, loosen the tension on the tension finger a LITTLE. If it slides down easy, tighten it a little. Fit the bobbin into the machine. Lift the presser foot (this releases the top thread tension discs) Check there are no bits of thread or fluff between the tension discs Rethread the top thread - check the thread path is 100% correct. Hold onto the end of the needle thread and draw up the bobbin thread. Hold both threads, start to sew - check the result. Tip : If you use a different color bobbin thread (same brand etc etc) it will help you to see more easily what is going on. You should be seeing some of the bobbin thread color on the top side of the sewing. If not, INCREASE top tension a little - retry.If there is a lot showing, decrease top tension. Good luck
1helpful
Thread is getting tangled in the bobbin chamber of my brother xl3125 when I sew. When I pull the fabric out, several strands come out of the bottom and the bottom side of the sewing is tangled and loose. ...
try these suggestions
change the needle
rethread the machine top 7 bobbin ---make sure the presser foot is in the up position before rethreading--use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case & that
the bobbin is not over full
Brother xl-2600I
try changing the needle
try tightening the top tension one number or letter at a time till the stitch look better
take the bobbin out & reinsert the bobbin into the bobbin case, also make sure the bobbin is not damaged
clean under the needle plate & in the bobbin area for loose threads or lint
3answers
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Thread keeps breaking
go to www.brother-usa.com and download your manual for free, it will have a troubleshooting guide to tell you what to do. Some ideas are that it is not threaded right, tangled thread or wrong needle for the fabric you are using. I am sure there will be the answer in your manual.
2helpful
Its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
