I bought this treadmill second hand and need a manual for it. It's a Repco Fitness RE1000. Thanks.
SOURCE: manual for free spirit model 30516
it comes from sears , this brand is built in jonesboro ,and is not a top of the line brand but does what most other treadmills do , you can probably go to sears and see if they have a treadmill like your in the showroom and then ask a salesman if the sears service center carries theese manuals or maybe he can tell you where to get one , their is no volume control on theese machines for the beep , but if you locate the sound holes which are most likely on the bottom of the display board you can use a piece of ductape and cover this speaker to make it less noisy ,Hope this has helped ,Sincerely glenn
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ [email protected]
cheers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
