SOURCE: Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
SOURCE: I have a samsung 52 inch lcd tv and it takes about
T-con or timing control board is defective or the syscon link board that feeds the panel itself... For that problem you'll need to take it to a shop - the whole Tv has to come apart to get to the T-con so it can be properly tested...
Good Luck!
William Rayburn, CET
Premium Technologies
SOURCE: When I turn on my
This problems very common on a LCD tv.It the tv power supply board,have bad dying capactors,these capacitors are alway bulges or puffing up on it tops.That the board,where the power a/c cord plug into it.U have all the tools,know basic electronic and can do basic soldering?Just check the power supply board,for those dying capacitors that bulges or puffing up on it tops.Replaced these dying capacitors on the tv power supply board,ur tv will power up normal again and have no more clicking sounds and will not take anymore 2 mins or more to turn it on.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
