I shut down my pc as usual and there weren't any problems before that day. When I returned, I tried to turn it on but nothing happened. Green light not showing at all yet when I opened it there is an orange light that is on inside (when plugged in ofcourse) that says AUX/PWR underneath. Can this be fixed?
Sounds like a power supply problem, find a local tech store for testing or just purchase and replace.
Dell computers parts are pripritory so you will need to purchase any needed parts from Dell.
This is most likely the power supply. You may be able to take it to a store like best buy for testing.
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
SOURCE: Orange light on Dell GX270 power button
I agree, the Optiplex GX270 is infamous for MoBos going bad. The capacitors have a manufacturing flaw, and up until February of 2008, Dell was replacing those boards for customers for free if it was found that the capacitors were the culprit. I just found a board yesterday with this problem. A sign that the capacitors are bad is either a buldge or they will be leaking an orange-rusted looking substance (primarily capacitors near the CPU). Symptoms of this problem include the PC rebooting itself randomly, and/or getting a BIOS error saying there was a thermal event.
SOURCE: Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
SOURCE: the power light comes on as orange
REMOVE board from cabinet then check you can easily track the problem
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
Hello everyone, check your cpu - I've just had one of these in for repair and the cpu was faulty - removing the ATX 4way 12v lead let the pc start rather then detecting a short and shutting the psu down. Changing the cpu cured the fault.
Thanks
