Question about LG Flatron L1715S 17" LCD Monitor
LG flatron L1715S
Hi after i power up sometimes my lcd goes white with vertical stripes... i when it works i can only use 640x480 resolution with high color 16 bits and a refresh rate of 60 Hz... anything above these settings it just turn white like i said and says "input signal out of range"..
Can you help
    Loyalty:
    Visited the website for 30 consecutive days.
  • 322 Answers
Hi, have you read the manual? More importantly have you installed the display driver on your machine?
LG L1715S Product Support Manuals Warranty More LG
Posted on Feb 03, 2018
6ya staff
SOURCE:
Anonymous
  • 202 Answers
SOURCE: OSD doesn't appear
You will find the number one motto from many of the Tech's is "If it ain't broke, don't fix it!!!" If you must fix it try the latest drivers for your video card and for the monitor. The OS(XP) is always changing. Keep the drivers up to date. Otherwise. Don't mess with it. Good Luck, Let me know what happens. Tim
Posted on Mar 07, 2007
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: Flatron L1715s goes always on power safe mode
press the menu button on lcd panel and chaneg the setting of power save . bye
Posted on Sep 24, 2007
Anonymous
  • 44 Answers
SOURCE: LG Flatron L194WS 19" LCD
check the VGA card of ur CPU.
load the LCD drivers
also check it's refresh rate, are they enable, if not then the VGA card did not accept the LCD properly. load the lcd drivers seperatly...
Posted on Feb 08, 2008
Anonymous
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
Anonymous
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Need code for interex adapter please help Tomas t.matos2@hotmail.com
MONITOR RESOLUTION SETTING
12" RGB 512x348 13467
13" RGB 640x480 66Hz 1467
PORTRAIT 640x870 23467
VGA/SVGA 640x480/800x600 60 Hz 2367
15" TILT N/A 2467
16" COLOR 832x624 1367
19" COLOR 1024x768 1267
21" COLOR 1152x870 123467
2 PG MONO 1152x870 3467
NTSC N/A 12467
NTSC/PAL N/A 12367
HI-RES 12-14" up to 640x480 1467
MULTI SCAN 14" up to 832x624 146789
MULTI SCAN 16" up to 1024x768 14679
MULTI SCAN 21" up to 1280x1024 14678
Jan 07, 2011 | Interex Serial adapter
Have Panasonic DMC-FX8 set for .3M picture size to download to Ebay; however the photo properties are 640x480 but 16 Million
If the photo properties are 640x480 and 16 million colors, then you're getting .3 megapixels. The number of colors has nothing to with the picture resolution.
Apr 17, 2010 | Panasonic Cameras
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
Default monitor
Sounds like you need to install your video card drivers, to get the resolution you need.
Jan 06, 2008 | Computers & Internet
LG Flatron L1715S 17" LCD Monitor Logo
313 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
