My Kenmore HE2 Dryer will not always cycle down and turn off. Most of the time the timer will stop at 21 minutes left and continue to run even though the clothes are dry.
We need the error code # please
All depends how long do you2 have this washer I highly suggest that you return it if is less then a year. if you opt to have ti fixed yourself you will be stuck in the "lemon law" policy, which is seriously broken.
just take it back, and do not let them talk you into sending a tech out.
An acvice for everyone: all front load washers are HIGH MAINTENANCE MACHINES! you MUST: use special soap/ watch the loads/ keep door open/ use mesh bags/ the list goes on!
Your rating is very important to me
Was this helpful?
Check your drain plug and clean it out at the bottom of the washer by removing the bottom panel
YES I have this same problem. I checked the owner's manual and didn't get much help from the trouble shooting page.
There is no error code
