The 3 large lens (which can clearly be seen on Model indicated here can be cleaned) Look first to the lens and on this set from rear look up and inside at the mirror in the rear---lens are more common than the mirror.
The screen is not working anymore and the built in light inside of the screen is burning out and the screen needs to be replace on the The TV's screen is either Dark or blurry picture is most often caused by the result of picture setting. If the screen is still dark after turning off Energy Saving, click Back on your TV's remote to return to the Picture menu. From the Picture menu, select Picture Mode Settings. Select vivid for the highest brightness, and most vivid colors.
Hey, could be many things, sounds like a main board problem if can not turn off with remote or buttons on set if any some new sets have to have remote. Need model number and age to help but if main can google part number off of board itself take back off it is the one with the cable hookups on it and see what it cost. One site is www.shopjimmy.com and try it. Good luck
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
1) replace the batteries by news ones 2) clean the contacts batteries 3) retight the spring contacts batteries with pliers. for better contacts. 4) Open the remote control and clean the KEY pads with contacts cleaners.
IF you do not have resolution, go the repair shop TV for fix it.
hi,
usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
also try this, facing the front of your screen. locate a button indicating " menu" and click it. once the menu button been activated there would be a display box indicating "AUDIO" "VIDEO" "TUNNING" or in some cases the screen will indicate one by one setting every time you press the "menu" button. If you'll able to find a display indicating "video" higlight the said icon and navigate throught it until you see the control for brightness. you can navigate the icon by pressing +/- channel button and to change the value of selected item you need to press +/- volume button of the screen.
Turn on the TI 83 enter 1234
1. press the <2nd> once; press and hold the <up-arrow> until you get the numbers as dark as you want. If you let up and press the arrow key again you have turned the function off. You must start over by pressing the <2nd> key then the <up-arrow> key and hold.
2. If the numbers are too dark; press <2nd> once and hold the <down-arrow> to get it corrected.
3. If this does not correct the light/dark screen condition you need to buy new batteries!
Just fixed mine.Remove the back of the TV on my model there in a small pwer supply turn the bottom of the two pots this will darken or lighten the screen. Fine tune with the settings on the remote
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
