Try hooking up your camera to your computer VIA USB. Power on the camera and see if your computer see's the Camera. If you do not have your cable just try and take a picture. Then pull the memory card out and see if you can see the picture you just took. If the camera still works you could try the link below. More then likely if the camera works you broke the screen.
http://www.smashedhat.com/sd300repair/
SOURCE: Black Screen
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
SOURCE: black screen in camera mode
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
SOURCE: Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Testimonial: "Thank you so much for taking the time to help me, i will try your suggestions tonight, really appreciate your help, thanks again"
