After putting charger on it takes ages for the charger light to come on, when it dose you can start the computer right away, this happens evan though the batterie is fully charged
SOURCE: Hi, I have a Toshiba
take out the battery and unpluge to cord from wall. put battery back in, then pluge it to wall outlet. turn computer on.
SOURCE: My Logitech Dinovo Edge is not recharging.
Im no expert but i had the same thing. would not charge, nothing i did made a difference until i did the following.
1- Had it in the cradle failing to charge as usual.
2- Went to the logitech setpoint (running the original CD version, no updates.
3- Clicked update the software.
4- got a error message after dealing with the update saying something along the lines of please reset this computer before running this command.
5- reset my compter and removed from cradle.
6- logged in and waited for the logitech software to update.
7- put my keyboard back in the cradle and clicked update again which it did. by this stage it was already charging as it should, green light.
this after MONTHS of not using it. so give it a go. it may NOT be broken.
SOURCE: I have a Emachines W3650, starts for a second,Makes one long beep
First you can get more information from the POST beep. (Power-on self-test (POST)). Using another PC from a friend or work search for this list on line. If you get one long beep there is an issue with the main board. Try taking out the memory and reseating each card. Also make sure the power connections to the mother board are good and tight.
SOURCE: T6528 emachine: one day monitor screen started
Upgrade the graphic driver in your pc.
I think its this one NVIDIA GeForce 6100.
Try also to look for loose connections.
Your support site:
http://www.emachines.com/support/drivers.html
And nvidias site: http://www.nvidia.com/Download/index.aspx?lang=en-us
If this doesn't help your screen has a defect.
Try to borrow a screen from a friend.
Good luck.
SOURCE: my computer won't boot up
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
