Problem with Bradford White M240s6ds-1ncww 40 Gallon Electric Water Heater - Sh BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT LOWES FOR DUAL ELEMENT UTILITECH BRAND. DRAINED HEATER INSTALLED ALL NEW STUFF FOLLOWING SAME WIRING FOR BW HEATER AND FILLED AND BLEED AIR OUT OF HEATER BEFORE TURNING POWER BACK ON. BUT STILL SAME PROBLEM ONLY HOT WATER FOR A LITTLE WHILE. CHECKED USING MULTIMETER AND UPPER ELEMENT IS GETTING 240 AT ELEMENT AND CAN FEEL IT GETTING WARM. BUT WONT TRANSFER TO LOWER THERMOSTAT OR ELEMENT. IF I MANUALLY TURN HEAT DOWN ON UPPER THERMOSTATE THEN IT WILL TRANSFER TO LOWER AND I CAN FEEL THE ELEMENT WARMING. BOTH THERMOSTATS ARE NEW AND ELEMENTS AS WELL. WHAT COULD BE THE CAUSE. ONLY THING I CAN THINK OF IS THE TUEN UP KIT THERMOSTATS ARE NOT COMPATABLE WITH BW.. BUT IT SAYS THEY ARE ON PACKAGE SO IDK. OR COULD IT BE MY DIP TUBE. BUT DIP TUBE WOULDNT CAUSE IT NOT TO TRANSFER TO LOWER ELEMENT WHEN NO WATER IS BEING USED RIGHT? SO IT HAS TO BE IN THE WIRING OR THERMOSTATS BUT ALL WIRING LOOKS GOOD
