Evrytime i turn on tv some blue screen turns on and says auto select signal searching
nothing else works not even the buttons on the tv except for the power button
i didnt get a manual so i dont know what to do ?
I have auto signal searching. I do not have the original remote.How do i reset?I have auto signal searching. I do not have the original remote.How do i reset?
AnonymousMar 20, 2014
Product code BU11FSRHD32Product code BU11FSRHD32
AnonymousMar 28, 2014
the power button on the bottom of monitor works but none of the other onesthe power button on the bottom of monitor works but none of the other ones
You can't post conmments that contain an email address.
ON THE REMOTE 1-PRESS BRIGHTNESS 2-PRESS FREEZE 3-PRESS MENU 4-PRESS ENTER YOUR SCREEN WILL BLINK BLACK AS TO RESET EVERY THING.HOPEFULLY IT WILL WORK FOR YOU.
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv.
recap
1. switch on the input eg video deck, DVD, VCD, or satellite dish.
2. switch on your AKAI PLASMA and
3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message.
The DON
To scan for digital channels on your Akai PDP4298ED1 TV, you can follow these steps:
Press the "Menu" button on your TV remote.
Use the arrow buttons to select the "Setup" menu and press "OK".
Use the arrow buttons to select the "Installation" option and press "OK".
Select "Automatic Search" or "Auto Scan" and press "OK". The TV will begin scanning for digital channels.
Once the scan is complete, the TV should display a list of channels that it has found. You can then use the arrow buttons to select a channel and press "OK" to tune to it.
If the auto scan feature does not work, you may need to try a manual scan instead. To do this, follow the same steps as above but instead of selecting "Automatic Search", choose "Manual Search" and enter the frequency of the channel you want to tune to. You can find the frequency information for your local channels by doing a quick online search or checking with your local TV provider.
CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
Rating: 1.9 - 37 votes
The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
U can't fix this problems.Omly replaced board.The Tuner main board have dead componnents.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for replacement.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Try selecting a different input, or checking the device which you are receiving the signal from. A blue screen typically indicates that there is no signal.
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Yes, I seem to have fixed the problem on my Akai using some creative google finds. One of two things worked - not sure which:
1. Leave the set unplugged overnight - it must let the electronics reset when the residual charges clear
2. For my Akai (remotes and models vary), hit in remote's sequence quickly - brightness, freeze, menu, enter - this places you in some screen that offers a hard reset option. That didn't work right away, but i did it before the option above and then the set worked again.
My problem was really odd because it worked for the component inputs and you could see the video and TV signals inside the PIP windows, but not full screen as primary input. Why the TV could 'see' the signals in a PIP windows but not detect them as primary I have no idea.
