Er appears in the refridgerator temp setting and dH appears for the freezer. Er appears in the refridgerator temp setting and dH appears for the freezer.
You can't post conmments that contain an email address.
Er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Unplug the LG fridge and wait 20 minutes - Plug back into power - Many times the code will clear or reset. If not keep reading below... -The majority of the time it is the freezer fan causing the Er FF error code. The FF error code indicates that the freezer fan motor is defective.
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right: Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService. Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service. For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService Er FS - Freezer Sensor Error Er rS - Refrigerator Sensor Error Er ds - Defrost Sensor Error Er dH - Defrost Heater Error Er CF - Cooling Motor Error Er CO - Communications Error
Error Code Er FF This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
FF(Freezer Fan) this is the fan that circulates cold air thru the freezer as well as the refrigerator. If this is the first time the er has appeared, you need to unplug the unit for about 10 minutes, plug the unit back in. This should reboot the unit and erase the er.
er ff indicates that the computer on your refrig is not sensing freezer fan operation. a guess as to your problem is that the fan is hitting on ice (the noise your hearing) and teh fan is not able to reach operation speed causing the error code. the fix would be to remove the ice from the fan area either maually or by unplugging the unit and letting it defrost for several hours. also to reset the computer you will neeed to unplug it for a few minutes then plugging it back up. hope that helps thanks Peyton
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
