Our washer has vibrated and jumped around for most of its life. just heard briefly on tv news that there was a recall related to this; didn't catch what to do. It sounds like a jet plane trying to take off in laundry room. Bought it 12/11/06 and the vendor no longer services LG products. Linda Rowe 559 585-8804 phone [email protected]
SOURCE: Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
SOURCE: Whirlpool Duet Sport Washer Door Reversal
well as far as a work around goes you can go to lowes and get longer hoses and cords and swap them around the door on the washer is not reversable because of the door lock how ever the drier door is hope that helps
SOURCE: washing machine on laminate flooring
Drill small plug holes to let the washer set on the concrete
SOURCE: Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
SOURCE: Washer not spinning or draining. Making LOUD grinding noise.
i started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
