Samsung sync master 743nx power on only 3 sec then fade what is the problem then?
My samsung sync master 743nx problem is when i plug it, it power on but for only 3-4 secs. but the power blue light still there. someone can help me solve the problem. i know little bit about basic electronix but i don't know where to pinpoint the problem.pls help for GOD will help you too when extending help to someone like me.GOD BLESS...
Samsung sync master monitors were well known for bad capacitors, if you have a esr capacitor meter you can check in circuit, if not look for dome shape at the top of the capacitor, a dead give away it is open, also check for poor solder connections in the power supply inverter board area.
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive IDE-0 means Pri master IDE-1 means Pri slave IDE-2 means Sec master IDE-3 means Sec slave single or master ::::: master with slave ::':: slave :::': black line between dots is plastic jumper note the plastic jumper is ' located at the rear of the hard drive betweenthe EIDE and electrical lead/s
I'm sorry to say that is a dead pixel, and it can rarely be fixed. Sometimes lightly massaging around the pixel will make it fade. This site here has a nice guide for that. If it doesn't work, it should be covered by Samsung's warranty depending on the age of the monitor. Hope this helps =]
How to troubleshoot a Samsung SyncMaster 743NX LCD
Monitor?
My Samsung SyncMaster 743NX
monitor turns on slowly. I mean,last week when I started up my pc,it
took 5-10 mins before my monitor displayed anything. I know the pc is
already turned on because I've already heard the Windows Vista start up
tune play. The problem is now getting worse as it now takes 20-30 mins
before my monitor displays anything. Please help.
