Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer MDE5500AYW drum screeching noise
Why when I put clothes in the dryer and start the drum makes a screeching sound product is a maytage neptune electric dryer model number: MDE5500AYW
5 Suggested Answers
James Chandler
  • 686 Answers
SOURCE: Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Posted on Feb 23, 2009
Kuwagata
donny ardalando
  • 208 Answers
SOURCE: no heat
Check for the wire inside the unit, maybe it's broken or cut off, replace or join it again will solve the problem
Posted on Oct 17, 2009
jimorris77
  • 411 Answers
SOURCE: reading error code 8.8
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the machine ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video on youtube which showed me how to take my machine apart. This video (direct drive washer repair) made it possible for me to do my own repair. You probably don't have any idea of the wonderful help you can get from youtube videos. Your first stop should be at youtube. Just search for the help you need. You could search for "clothes dryer repair" or "clothes washer repair" or "dishwasher repair". If you are not able to view and/or download the videos, or after you've seen all you want to see, I suggest you go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers, dryers. and dishwashers as well as other appliances. Another excellent site is www.acmehowto.com If you have a direct drive top load washer and need help taking it apart these youtube videos are wonderful help. I was so impressed with them that when I saw all these people needing help, I wanted to tell them about the videos. If you look at the back of your top load washer and the panel is solid (no small inspection plate to remove, which would indicate you have a v-belt drive) chances are you have a direct drive and this video (direct drive washer repair) is just what you need. After you've seen all the appropiate videos, or if you have a belt drive washer, you will probably still need help in determining what the trouble is and how to fix it. I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Another excellent site for DIY help is www.acmehowto.com Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you where you can get help to solve the problem. Good luck with it.
Posted on Dec 21, 2009
marka19
marka19
  • 1430 Answers
SOURCE: Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Posted on Mar 31, 2010
Testimonial: "Good advice fast. Thanks very much."
sandysummer
  • 14 Answers
SOURCE: My Maytag dryer makes an awful screeching sound
I recently replaced the rear drum bearing on this dryer, and once you find the part, the change is a snap. The dryer actually uses Whirlpool parts, and the rear bearing is just a plastic bushing that the shaft of the drum rides in. It is accessible behind a small cover on the rear of the machine. Pop the top off the machine (so you will be able to support the drum, to remove the old bushing), remove the five Robertson screws holding the rear cover and bushing in place,remove c-clip at end of shaft, remove old bushing. After applying some high quality lube (I used a molybdenum based product), reverse assemble, and enjoy the now quiet machine.
The part # is 35001012, made by Whirlpool (Maytag/Samsung), FSP on the bag.
Posted on Feb 26, 2011
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune model mde5500ayw make a sound like metal grinding, comes and goes, it looks like the felt liner in the back is loose in one area. Is this the cause of the bloody awful noise?
If the noise is intermittent then most likely the loose felt is not the best problem. More likely is the rollers that support the drum. You can take them off clean and oil with a good bearing oil and that might work or you can replace them if they are too worn
Oct 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune mde5500ayw chirping, buttons wont do anything. was told to replace control board. that did'nt help at all. any ideas?
The blower wheel on these tends to wallow out. That makes the dryer overheat and take twice as long to dry the clothes. Lint begins to build up in the filter housing. Finally the temp exceeds 350 and the round white fuse on the blower housing melts. Boom you has got a dead dryer. To get into the slopefront type dryer seems a bit intimidating bit really is not. Remove the door. The door is reverseable so 2 more screws opposide need to also be removed. Then the goalpost shaped front pops off. Then that reveals the top hold down straps. Remove them and top can be popped. Next you remove the front shroud the drum rides on. then get the drum out. Did I mention you do not work from the back at all on this model? Do not try to fix it in the wash room. Take it ouitside and put it on the picnic table or a tailgate to repair it. You will need a phillips head screwdrivers pliers 1/4 and 5/16 nutdriver and snapring pliers.
Shopvac to clean it up and probbaly a new fuse and blower wheel.
SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 31, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Something is stuck in dryer, possible kids toy
that means it just has too much clothing in it, take some out!
Mar 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
- very loud squeaking sound
Hello JewettKann,
Typically, on the Maytag Neptune dryers, it is the felt gasket that is the cause and source of the noise you're hearing.
There is a felt gasket that runs all around the front and rear of the dryer drum and cabinet door edge (on the backside lip). As the dryer ages, this felt wears out and needs to be replaced to prevent the awful screeching sounds you'll experience, once the metal to metal contact becomes constant.
You can view the parts that need replacing at the following link (Item #17B on the drawing) Called a sound damper pad on some models.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDE4000AZW&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=MAYTAG-LAUNDRY&diagramPageId=00004&componentDescription=DOOR&documentId=M0402169&blt=06
This was a fairly common problem with the Neptune line. You can see for yourself by simply turning the drum with your hand and feeling and listening for the rubbing/grinding noise, along the top of the door opening.
If you can get the complete model number off your dryer, you can select the exact line drawing and parts list at the link below to make sure you're looking at your exact model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=mde4000&=part+number
I hope you find this Very Helpful and best regards!
Dec 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag sde3606ayw make loud screeching noise
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Dec 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
DRUM/TUMBLER ISSUE
look at the rollers of the drum, it could have been dameged already and needs to be replaced.
Mar 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
281 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
