IR sensors are tough devices firts make sure that your remote control is working view its ir led light using your phone camera you should see it flashing..another test is puting it near an AM radio ,you will hear an interference when you push any key. then the crystal is all right.Replacing the IR sensor means you really have to unsolder it from the circuit board and fing a replacement..I hope its just one of those cold solder ang not the IR sensor..Good luck.
SOURCE: new phillips tv model 42pfl7403d/f7. remote quit
then i would say the remote diode in the tv has malfunctioned. you will have to have it tested and replaced.
SOURCE: Where can I buy an IR sensor board for a 42"
SHORT CAPACITOR ON IR BOARD NEAR CONECTOR FROM KEY BOARD ITS THE PROBLEM FOR REMOTE COMANDER NOT WORKING .
SOURCE: where can i find a ir sensor for my Philips
There are plenty of places you can look. Shopjimmy.com. Tiger parts direct. Encompass parts are just a few. Just google the part# and some part suppliers will pop up.
SOURCE: part # for 52PFL7403/f7 for ir board sensor
Look on Encompass Parts Distribution type in your Model Number .1-800-638-3328
Try Shopjimmy.com
SOURCE: phillips tv model 47pfl5603d/f7 power
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
