You have no sound on just Youtube? Or is it anything that should be playing sound? If the latter, you might try clicking the Mute button on the right side edge of your iPad. If it shows orange, it's on mute, slide the switch to unmute. If that makes no difference, try turning up the volume, by pressing up on the long button just below the Mute slider.
It is very possible that the earphone jack is defective and causing the problem. I had a tablet that would not make any sounds through the speakers after I plugged into the earphone jack and then removed the plug. I could hear only through the earphones after that. The problem was caused by a fault in the earphone jack. I had to send the tablet back to the manufacturer where they replaced the faulty jack. But before you send the tablet back to the manufacturer make sure that the tablet isn't muted by going to "settings" then go to "sound" and see if it is turned down or muted.
tablet setting icon gear shape has sound display option from ringtones to touch sound.And volumes,increase bar section on volume to maximum to enable sound in case it was disable.
All you do is turn off the screen sounds and screen lock then hit the mute but on sound and notifications and walla all of these other people try so hard and my user account on ps3 is NEXION218 peace check my vids on YouTube macahima subscribe I'm a kid 11 I know fasinating
The mute switch is on the right side of the iPad. Check your switch settings first:
Tap Settings > General.
Under "Use Side Switch to:", select Lock Rotation or Mute. Settings > General
Make sure you're using it to mute, and then slide the switch to toggle mute on and off. Also use the volume rocker in case you have the volume set too low.
