Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
SOURCE: Model number on my Frigidaire stackable washer/dryer is wore off
ckd dryer door and door frame
SOURCE: Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
SOURCE: Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
SOURCE: I have a frigidaire stackable
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Hi L Martin - For this particular model FEX831CS0, the heating element part number is 131475320. The part may be purchase directly from the manufacturer or through a part distributor in your area.
