The Tray 4 is acting up on the n4525. Sending a print job to this try results in a "Wrong Size" error message. This tray was used successfully for years previously. Another clue may be the tray, when paper is added, the try does not always lift the paper to the top. The sound of it lifting does occur yet no matter how much paper is added, it seems to fail lifting completely. Tray 4 is a 500 sheet tray attached to n4525 bottom.
The model with this issue is actually the Xerox DocuPrint n4525CN Laser Printer. This model includes a total of 5 trays, with wheels, the duplex capability and a Multi Bypass Feeder. It does NOT have the sorter, envelop feeder nor the staple feature.The model with this issue is actually the Xerox DocuPrint n4525CN Laser Printer. This model includes a total of 5 trays, with wheels, the duplex capability and a Multi Bypass Feeder. It does NOT have the sorter, envelop feeder nor the staple feature.
You can't post conmments that contain an email address.
Tektronix printer paper trays, I seem to recall that there's a plastic key that fits on the right side of the paper tray. It's a little plastic piece that just clips in on the right side of the paper tray. Sounds like it's missing
This should open a screen showing the key information about the Driver Files and their End User License Agreement which you must agree to start the download.
make sure you have the right paper size settings. The paper loaded in the tray might be shorter than the setting in the document. Check also the output size in printer setting.
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Here you go UNITED DATA TECHNOLOGIES INC 8825 NW 21ST TERRACE DORAL, FL 33172 Phone: 305-882-0435 Fax: 305-882-0436 Products Serviced: Phaser 8200, Phaser 860
MONARCH ELECTRONICS INC SUITE 319 1440 79TH STREET CAUSEWAY NORTH BAY VILLAGE, FL 33141 Phone: 305-866-1885 Fax: 305-865-8087 Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
Make sure the machine and the driver are set for A3 . Most likely the paper tray, or setting in the menu are not correct.
Or the driver paper size is not correct.
