When I press the start button all lights go off and the 'spin' and 'short wash' buttons remain on and the machine beeps. My start button was broken so I replaced the circuit board and now it won't start. Please someone help me!!
That is Error code 9
9. (00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
SOURCE: Fisher and Paykel smart drive
You have a control board problem that I would never advise replacing on this brand.The amount of headaches I see in my customers who own this can right a book.Sorry my friend.
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Thanks so much!
