Televison & Video Logo
Posted on Jan 15, 2009
Problem with Poloroid LCD 32 in. TV
While watching the TV all of a sudden it starting humming and on the screen appeared diagonal lines of blue, black, and white I believe with the word Sunday in the middle. The word Sunday began disappearing and the screen went black. I thought it was from the broadcast station. Not so. The blue light comes on when I turned it on but not picture or sound. I have tried unplugging it. Can you help? Thank you for your time.
  • djstormjam Jan 15, 2009
    same problem, same model tv
  • mortimer1949 Feb 07, 2009
    I have vertical lines as well with the picture sometimes looking polarized and a loud humming when turning on the tv
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jan 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
4195
Points
34
Stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
My TV is turned on and I'm watching it but the status light on the bottom is flashing between blue and orange. Do you know why?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
5helpful
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
5helpful
3answers
I was watching the tv, when the screen went blank but the voice was still on, then smelled something awful, like something plastic melting, then noticed a lot of smoke coming up from the back of the...
Most probably, Electrolytic condenser in the Power supply to display circuit may have punctured resulting in smoke coming out. Take tv to service centre. There is no other option.
Good luck.
Rating the solution is highly appreciated.
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
10helpful
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Sylvania 6620LCT 20
throw it in the landfill there are no replacement parts.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
