Although my screen appears as normal my cursor will not move.
SOURCE: My laptop mouse ( model lenova Y410 ) is inactive
Have you tried checking your mosue configuration in Control Panel? Do you remembeer what happen just before your mouse stop working?
Thanks,
C2Solutions
SOURCE: Mouse changing my page size
Your Ctrl Button is continously being pressed that is why this is happening. You can restore the page by pressing both Ctrl + Upper Arrow in case to increase the size and for reducing the size press CTRL+Down Arrow
Testimonial: "On the ball"
SOURCE: blank screen appears on the startup with only cursor on it
The Acer Recovery CDs do not set the Boot flag on the hard drive. I had to manually set the boot flag to on using GPARTED Live. After restarting using the GPARTED CD, you can manage the flags under the partition drop down and click on the Boot flag. After exiting GPARTED, I rebooted the laptop and no more black screen....fixed!!
I hope this helps others.
SOURCE: Laptop cursor not registering when pressed
Ok on keyboard, press WINDOWS logo see start page comes up. using keypads arrow keys, access the control panel, find mouse, if you are using vista, set classic view. you may get around by tab key and up>down>rigth>left arrow keys.
Install driver again or use update \. come back start and shot down the computer by shotdown arrow, do not use brown button will not shotdown, it is stanby (On vista). Then turn on again see what you see>
If can not, Just use same system and reach out the system tools from accessories>system tools>Make defragmentation.
No result > make system restore. No result see tech.
JMC
